Had another good day at Roger's, we finished the taper on the clutch end of the shaft, and then cut key ways for the gear end of the shaft.
Then it was to cut the notch for the locking washer that goes under the nut that holds all this together on the gear box end
Here it is with the clutch assembled and the measurements checked and looks like all will fit together like I hoped. Now it is time to turn it over and start to assemble the gear box side.
Need to give a big thanks to Roger's Machine Shop for all the help and expertise on getting this done correctly
