Port Huron Rebuild
Discussion in 'Steam Traction Engines' started by Jerry Christiansen, Jan 10, 2016.
    A few pictures of the action at Larson Welding on 9 Jan 2016.
    Ray drilled and tapped a lot of holes in the Port Huron boiler. Here he is getting set up to drill holes to mount the left hand driver.
    Ned expalins some facts of life to Louie.
    Three crews working on the Port Huron. Holes are being drilled and tapped for the right hand driver. Another crew is drilling and tapping holes on top of the boiler to mount the engine. A third crew is cleaning parts.
    Mean while in the other bay of Jim's shop parts are taken out of a trailer and cleaned.
    The original steam dome will be put on just for appearances. The bottoms of the rivets were are gound smooth, then spot welded so they won't fall out.
    More pictures coming.
    More pictures.
    Louie really isn't going to eat that donut, he said he was inspecting it for Wimpy.
    More Port Huron parts getting cleaned.
    More holes being drilled and tapped.
    Installing studs, getting closer to putting a driver on.
    The axle is slid in.
    Installing the righthand driver.
    More coming,
  3. Jerry Christiansen
    The last of the pictues I took.
    Obviously they are discussing BOD matters.
    Mel is still cleaning parts.
    The Port Huron had a lap seam boiler. The new boiler is a welded boiler and doesn't have a lap seam. The seam from the old boiler is getting cleaned up and will be bolted on so it will look like a lap seam boiler.
    Kenneth and Marlin drilled holes to mount the smoke stack and cut out the hole for the smoke stack.
    I left the shop around 1:30. I hope someone else will share some pictues from later in the day.
    I am still hoping for more pictures from Saturday and maybe Sunday.
    I happened to drive by Jim's shop today and saw what the crew got done. I didn't have a camera with me, so no pictues.
    The Port is sitting outside the shop with all its wheels in place. The smoke stack is in place and the engine is bolted in place. The crew got a lot done after I left.
    Congratulations to all involved. Thanks for the hard work.
  5. Ray Wangler
    Ray Wangler Intermediate Poster WMSTR Lifetime Member
    Jerry, I’m really proud of all the work that got done and more importantly the people. We had tremendous crews! Even you and I worked together well. Everyone worked hard plus we had a very fun time visiting. The Port Huron went from “started” to clearly “in progress”. There’s still a ton of work to be done, but much of the heavy lifting work is behind us. I’d think platform and bunkers will be the next big job, steam dome, frivets, lap seam, followed by lots of levers to mount and finally the plethora of piping to be installed. Jim wants to be running by steam up in April which is an incredibly aggressive goal………..but as the sign in my office says, “you miss all the shots you don’t take”, so an aggressive schedule will keep us focused on the end. I'll be out of the country for the February work weekend, but hopefully we can get some work done before that.
    Congratulations to all the crews that worked Saturday, it was a tremendous success!
  6. Ned
    portpic.JPG I meant to post this picture but we had a passing in my family so it's a couple weeks late but this is the Port as she rolled out of the shop on Sunday morning on all four wheels. Awesome job to everyone involved still a lot of work ahead but we're getting there and hopefully we will have steam on by April for the MSEA steam up
    Ned
    Bjorn2, Lee, mrnewway and 1 other person like this.
  7. Ray Wangler
    That thing that use to look like an anemic hunk of overgrown pipe is starting to look like a steam engine! Thanks Ned.
    The Port Huron was back in the shop on Friday morning with a crew ready to go to work. I stopped by after I got off work Friday afternoon to see who was there and check the progress.
    Hartley and Louie were working on installing the sheilds over the gears. I believe the wheel on this side had to come off so they could get enough room to work. Look through the flywheel and notice the steam dome. The new steam dome is very small compared to the original.
    Work on the original steam dome started on the last Work Weekend. Ned dod some more work and is getting ready to lift it into place.
    Noah is on the boiler setting the steam dome in place. More members of the Friday work crew stopped what they were doing to watch.
    After the steam dome was in position, Ned did some final fit and cut holes for the pipes to come through. Four holes will be drilled and tapped to hold the steam dome in place.
    Here is a picture from the other side. If you look closely you can see that one rivet is missing. That is where one of the bolts will be installed to secure the steam dome. The chalk drawings on the boiler are from a couple weeks ago when we were discussing the loactation of the casting that holds the axle.
    Bob C is installing the foot pedal for the brake.
    Ray W repaired a bracket for the brake.
    I wasn't able to go to Jim's shop on Saturday or Sunday. I hope someone that was there will provide an update of the progess.
  9. Ray Wangler
    Jerry, I didn’t take any pictures L, but we did get a bunch done on Saturday. The castings for the hitch and platform were installed and the hitch went on after Jim and Ned beat it into submission…………certainly didn’t fall on there, but they got it. The firebox door ring got installed, wheel rub castings, the steps and standing platform on the left side got installed, the clutch, throttle and reverse lever are installed, and the governor was in place when I left around 4:00 pm. It was a banner weekend and it’s starting to become clearer how it MAY run for steam up! Still a very aggressive goal with lots to do. I see the biggest jobs as:
    Main Steam piping
    Exhaust steam piping and nozzle installation
    Setting the timing and staking the reverse block casting
    Piping (not plumbing according to Tom Dillon) of the two injectors (this, by the way is no small task!)
    Install linkages for clutch, throttle and reverse
    Install the smokebox door
    Make and install clutch shoes
    Install the bunkers in the platform
    Make and install keys for the flywheel and left side bull pinion
    Install the canopy
    Trim, (whistle cord, lubricators, draft door chain, rear step……..this, too, is not small and takes a lot of time)
    Maybe someone else can add to this and it's our "punch list" to ensure we get everything done.
    Good luck in February!
    Ray
  10. Jerry Christiansen
    Ray posted a list of things done and things to do. I stopped by Jim's shop and took some pictures after work today.
    The engine and all the drive gears are in place. The steps, governor, steam dome and levers are mounted. The sheild above the gears is in place, but can't be seen in this picture;
    The framework for the platform and bunkers is in place. The firebox ring and ash pan door are ready to go.
    Now the sheilds above the gears can be seen.
    This angle shows the brake pedal a bit better.
    One of the bolts holding the steam dome in place can be seen. A lot (jsut about all) of piping needs to be done.
    The wood blocks for the clutch need to be made and installed. The lugs on the Port Huron drivers are part of the wheel casting. Wimpy would need to burn a lot of rod to build those back up.
    A close up showing a tandem, compound steam engine.
    Thanks to everybody for all the work!
    By the way, when I took the pictures at 4:45 the temperature in Fargo was 37 degrees F and rain was falling.
  11. Jerry Christiansen
    I happened to call Larson Welding today about a different topic and learned that Mark K and Hartley E were spending time on the Port Huron today. I stopped after work to take a few pictures and talked with Jim about the progress.
    The governor is piped and the hole coming out of the steam dome has been dressed up. You can also see that most of the studs have been trimed.
    It may not look like much, but the hole for the blower valve has been drilled and tapped.
    The valves for the water glass have been installed along with the try cocks. The holes for the injectors are drilled and tapped and the locations of the feed water pipes have been laid out.
    It may not look like much was done, but a lot of measuring and figuring has to be done before holes are drilled in the boiler.
    Thanks to everyone for the work that is being done on the Port!
  12. M Kerkvliet
    Full disclosure... It wasn't me! Which Mark K Jerry?
  13. Ned
    The mystery Mark was Mark Knox
  14. M Kerkvliet
    Got it! Great initials Mark has :)...
  15. Ray Wangler
    looking good guys! I'm on the other side of the pond right now but i'll be back soon. sure great to see the project progressing! Jerry keep the pictures coming........it's amazing to see how far that has come.
  16. Brian K. Nelson
    Brian K. Nelson Mega Poster WMSTR Lifetime Member
    Tia Braseth and mrnewway like this.
  17. Merlyn Meyer
    Merlyn Meyer Intermediate Poster WMSTR Lifetime Member
  18. caveman
    caveman Junior Poster
    Is the serial number known please?
  19. Jerry Christiansen
    Hi Caveman,
    I am certain that someone knows the serial number, I don't.
    Where is the number located on a Port Huron?
  20. Sanders E.
    Sanders E. WMSTR Lifetime Members WMSTR Lifetime Member
    Jerry and Caveman,
    If I remember correctly, the serial number is on the smoke box door. However, I do not remember what that number is off the top of my head...
    I have a short article about the engine at home that I will post later this afternoon, I think it has the number.
    Sanders
