1. This site will be upgraded to the latest version of xenForo (the platform it runs on) over the next few days. There will likely be a few bugs that will need to be worked out and it will look a little different. Using the site will remain the same, or close enough that it will be easy to figure it out. All of the content will be retained so no worries there. If you try to check in and have some trouble, be patient. Things will be back to normal very soon. Thanks!
Picture test #1-001
Discussion in 'Test Forum' started by pmasley, May 4, 2007.
  1. pmasley
    pmasley Intermediate Poster WMSTR Lifetime Member
  2. 40avery
    Good job!
    It comes up great.:dancingparty:
  3. pmasley
    Picture post
    I used a size of 640x480 and the picture came up pretty small on my screen (about 1.25" x 1") which makes me think I need to resize the picture larger on next attempt. Is it only small on my screen?
    Peter
  4. M Kerkvliet
    The picture is just a thumbnail... Click on the picture and it will re-size to the 640X480. It works OK for me!
    If you really want to get fancy, open a photobucket account and use off-site hosting. Then you can have your pictures right in your message. It is really easy to do... and free!
  5. 40avery
  6. pmasley
    Learning more
    Ok, good information. Photobucket makes sense esp. in terms of saving server space, But....I'm having trouble uploading the links as I keep getting the message that the link file is too large (even though I've resized them to 650x480 and kept the size to about 95). I will work on this but right now I'd rather post some pictures to the Ortner Section so Dan & Dawn can see the progress and get to work on the doors for the building. Thanks for the help.
    Peter
  7. pmasley
    Hi Peter,
    If you have that picture on Photobucket, you can put it in the text. When you get to the place in the text you want the picture, click on the 5th icon from the right just above the window you enter the text in. The icon is supposed to represent a picture of a mountain scene with the sun in the top right corner.
    When you do that another box will show up on your screen. If you put the URL from Photobucket in the box, the picture will show up in the text. When I am doing that I have two browser windows open. One is opened to this site, the other to Photobucket. I "click" on the tab in Photobucket that says http. The word "copied" shows up on my screen, then I put the cursor in the box on this site and paste. If the http//: shows up twice, you will need to delete one of them.
    Good luck,
    Jerry
  9. pmasley
    Pictures
    Thanks Jerry, I'll get the hang of this yet. Found out that even with links I need to make the pictures smaller pixel and size wise. I sent you an email over the weekend to your private email address about the bridge Jerry. Did you get it?
  10. Jerry Christiansen
    Hi Peter,
    I changed my address a while ago. I will send a pm with the current one. I didn't get a message over the weekend.
    If you look at one of my posts that has pictures, I saved those pictues as a 640 X 480.
    Jerry
  11. CaseyD
    CaseyD B & R Sawmill Crew WMSTR Lifetime Member
    i'm just trying to figure out the named quotes
  12. Jerry Christiansen
    Hi Casey,
    I you are wanting an explainaiton, I am not certain I understand your question.
    If you are meaning "click", that means left-click.
    Jerry
  13. CaseyD
    No, sorry--I was just playing around to learn how to insert a name into the quote box...the text that I copied was completely unrelated. Alas, now i know how to attribute a quote to a specific user!
    sorry,
  14. pmasley
    need to remember how to do this
    ok, try attachment instead of picture
  15. M Kerkvliet
    This is a test reply
