Usually the second Saturday of the winter months are Work Weekends at Larson Welding. While there weren't enough projects to announce a Work Weekend, a small group of people were there on 12 February working on a couple projects.
Jim said that is 30 Hp Avery Skid engine. New skids were built for the engine. A die grinder is being used to make pockets in the bottom for the bolt heads and washers.
The skids spent a little time in the far corner of the shop where the holes were drilled all the way through.
Kenneth set this shaft up on a mill to cut some key ways.
A key way was cut on each end. This shaft will replace one that got bent in a sawmill.
A preheater for a Case Steam engine was built.
More fitting in the press.
A lot of clamps to hold things in place. The crew also used a big torch and hammer for some of the forming.
Notice the fellow on the left with the coffee and donut.
More pictures to come,
