15 HP Reid
Discussion in 'Stationary Gas and Diesel Engines' started by Dustin D Ehli, Mar 10, 2015.
  1. Dustin D Ehli
    Dustin D Ehli Junior Poster WMSTR Lifetime Member
    Everyone, This has been our latest project.
    It is a 15 HP right hand longshaft Reid.
    Serial Number 4477 which puts it at 1909
    It was used on one of the original Frank Phillips oil leases in Bartlesville OK, right next to the Caney river to pump 7 oil wells.
    Since the video we have finished up work on the clutch shoes and a few other things.
    Pretty good gouge in the bore from the wristpin but it still runs good enough for show purposes
    Hi Dusty,
    Would a person have to re-sleeve the engine to fix the gouge?
    Is the engine running at governed speed?
    Are you bringing this one to Steam Up?
    That should be enough questions for one morning.
  3. Dustin D Ehli
    Jerry,
    Probably could get away with JB weld to fill the gouges for a show engine, for now we are leaving it as is since it runs good enough.
    Rated speed is 165, in the video we are around 60 or so, we do not have the governor for it, so it is just us controlling speed with a valve on the intake and a needle valve for fuel control.
    Steam up, what sense does a gas engine have being at a steam event, although it would be fun to fiddle with it on a brake some day since it does have a clutch.
  4. M Kerkvliet
    Nice video Dustin!
    Anything old like that is welcome at the Steam Up! Especially since steam stuff may be in short supply there this year!
  5. Dustin D Ehli
    When is steam up anyways, ill have to see if we could make it work.
    Would need my brothers to help run it
    Hi Dusty,
    I will get Steam Up on the calendar soon. In the mean time, Steam Up is 11 April 2015.
  7. cjmlarson
    Bring it, I have brought a truck, diesel engine, buzz saw, and pieces that I was rebuilding on the Russell one winter.
  8. Dustin D Ehli
    Ill see what we can come up with, if it works maybe we will bring it, hopefully it is not a muddy mess like other years.
    Jerry, are you going to have a brake there??
  9. Jerry Christiansen
    Hi Dusty,
    Yes, the Blue Brake is planning on being at Steam Up 2015.
  10. Dustin D Ehli
    Well we will see.
    If it works out we could bring it up maybe, get our 100 lb tank topped off and run it for a while.
    We run it on propane
  11. Jerry Christiansen
    Dustin,
    Will you tell us about the Reid engines? When they were used in the oil fields, did they run on natural gas that was taken from the well? Are some of these enignes still in use?
  12. DOXEY41
    I personally would like to see this engine at steam up hope it works out!
  13. craig mattson
    craig mattson Mega Poster WMSTR Lifetime Member
    It would be great so see this engine at steam up!
  14. Dustin D Ehli
    Yes used in oil fields mostly in the east.
    Reid started building engines in the mid 1890s out of business in 1939 I believe
    Built in oil city pa, most ran off well head gas and also used it for the hot tube so they had free reliable ignition.
    It sorta has a bark to the exhaust so would it annoy people if we brought it to steam up. We will see, no promises yet
